Vsc Light
belfast gs300
Could be one of the abs sensors as work was being done in that area. The vsc needs the sensors working so that it can tell when a wheel is spinning.
What I mean is, one of the abs sensors or its wiring could've been knocked or damaged while the ball joints were being done. Best bet is to get a local garage to read the fault codes to give a better clue.
