New Discs & Pads
Rich OB
Quick question peeps. Opinions/experience/advice.
I'm soon to be needing new discs and pads all round. The question is...
1. Go with OEM
2. brembo Drilled & Grooved/EBC Green Stuff pads
3. Other?
Ok so my standard engine doesn't require uprated brakes, but cosmetically they look better behind 18" sport rims right?
I can get option 2 for about £380? OEM would be £280.
1. Go with OEM
2. Brembo Drilled & Grooved/EBC Green Stuff pads
3. Other?
A couple of weeks ago I was quoted £304 incl of VAT for OEM all round.
1. Go with OEM
3. Other?
£304 for OEM discs and pads front and rear? Was that fitted, and, where was it from?
I thought it would be significantly more.
Andrew
1. Go with OEM
3. Other?
Andrew
To buy. Does not include fitting. From a Lexus Main Dealer
I got a quote from Andy on the forums. £285 for OEM discs & pads all round and hand brake shoes. Of course plus fitting. I will use Westfield motors who I normally use.
Igino, do you mean Greenstuff pads are NOT good??
So who'd go with brembo over OEM?
Rich; is that a mates rates price from Andy, or is any forum member able to get them for that price?
My local dealer has just quoted £510 fitted; obviously if I buy the parts from Andy for < £300, my local mechanic could fit them for around £100.
Thanks again
Andrew
