Precautions To Start Your Soarer After Eight Months Stationary?
markgize
My Soarer has been stationary since November 2010. Aside from the flat Battery, what precautions should I take before attempting to start the car or should I simply give it a go?
Thanks for your time.
Mark.
It will probably be OK, which engine is it?
Check the oil level before doing anything.
But....
It may be an idea to turn the engine over by hand a few revolutions the same way the engine normally rotates to make sure nothing has seized using a rachet and socket on the crank pulley centre nut.
Once that checks out you could also disable the ignition to prevent the engine firing and spin it over a few times on the starter to recirculate the oil around the engine.
Finally you could also remove the plugs and give each cylinder a little Redex or similar just to provide a little protection to the cylinder bores on start up.
Obviously once it starts don't rev it excessively until it has warmed up fully particularly if it is a turbocharged version.
Finally before driving off check the brakes are working!
