Hi All, has anyone fitted a Dump Valve to their IS220d in a bid to remove the flat spot under 1600rpm? I know this wont cure the initial run to first gear but once the turbo is runing, it should improve the other gear changes. I have seen a couple of after market electronic Diesel Dump valves but wondered if they are any good for the Lexus?
see Link below
http://www.racespecp...Dump%20Valve%22
I don't think it will help as IS220d has the dump valve - I suppose every turbocharged car has it as a standard. The difference between standard and aftermarket is, that standard doesn't blow to atmosphere, and is very silent.
Try to drive with open windows and I am sure you will hear it working.
