I'm also wondering how you set the mirrors to 'turn down' when you put the car into reverse. I've went through the menu for parking sensors etc but it doesnt allow me to change it from no to yes for the mirror option (which may be the wrong thing!)
Make sure your mirror selection switch is either set to left or right. If it's in the 'middle' then the mirrors will not dip.
No, Like the man said the mirror select switch has to be in either the right or left mirror position and then they will dip :whistling:
Thanks guys, would seem the mirrors have to be at left or right, works fine now!
Thanks all xx
