Altezza Diagnostics
possel
i have tried a few diagnostic mechines and not had any luck, i no that mitsubishi evos have a programme called EVOSCAN which is installed onto a laptop then use a usb to OBD-II connection to read codes, remove speed limiter, alter ecu settings ect. does anyone no if there is a similar programme that i can get hold of that will work on my 1999 altezza? any help would be appricated
