Locking Wheel Nut Covers
rangermastiffs
I wouldn't worry about fitting locking nuts just fit 5 normal nuts instead, BTW where do you normally park the car? :whistling:
I had the same problem I bought some 19mm plastc "chrome" nut covers on Fleabay for about £10.00 which go over the standard Lexus nuts fine but with the locking nuts having a round profile they were a loose fit on them so I made some plastic inserts to fit inside the cover and make them fit tighter. They haven't come off yet or stolen as you need the "special tool" (plastic tweezers) to remove them as they are deep set into the holes on the wheel.
Finally let see the new wheels then :D
