Coolant Loss
NEOCON
Hello,
I seem to be loosing coolant at an alarming rate in my IS200. I filled up the expansion tank to above half way mark on sunday morning on the way to TRAX and I checked it this morning and the level is showing empty :o
I cannot see any evidence of the coolant leaking anywhere: the engine bay is all dry and there is never any wet marks under the car. There is however some dry yellow-ish residue next to the water pump so I wonder if it is somehow evaporating through it.
Does anyone have any suggestions of what else I should check around the engine for any obvious signs?
I had a quick look at the radiator earlier and there seems to be a wet spot at the bottom of it, where the undertray sits. This is on the passenger side of the radiator. Is that where the drain plug is located?
I already had a look on fleabay and new radiators seem to be reasonable cost. I think I'll get under the car this weekend and take a proper look at it. I hope the drain plug is just loose otherwise I'll just buy a new rad.
On a different note - is the water pump easy to replace? I've just ordered a new one.
