Sign in to follow this
Lexus-IS
How To Check Brakes
can anyone tell me how I can check my front and rear brake discs and see if they are worn to minimum thickness? and also the pads? thanks
A micrometer and a spec sheet!
I replaced mine when there was a significant wear ridge on the fronts. They seem to wear quickly - looks like a car that will need front discs at every pad change with the oe stuff.
where can i get spec sheet from?
Apologies, I've just seen your reply. I was being facetious - I suppose you could ask a dealer what the minimum thickness for the disks is but if you are using standard stuff I would replace the disk if there is any significant sign of a wear ridge. The parts are pretty cheap - buy on ebay from Lexus Birmingham.
