Oem Front And Rear Brake Disks + All Round Brake Pads
grandb3rry
Hi chaps! Hope everyone is doing great. (and enjoying the last rays of English sunshine before autumn & winter kicks in)
I have a question as the heading suggests, I bought OEM Front and rear brake disks and all round brake pads. Would I be able to fit this myself or is it something that a professinal better do?
Many thanks for your kind help!
Arthur
Front will be handy enough.
Rmove caliper and caliper housing
Disc should come off with a good pull or thread an m8 bolt into small hole (this will work like a set of pullers)
Remove disc and clean and replace with new
For pads just take cap off brake fluid reservoir and push piston back using a g clamp
For the rear would be similar.
Think rear has shoes so you will need release handbrake and maybe adjust a little to remove brake discs.
Again clean and blow inside when disc removed
Then fit new disc and adjust handbrake cable until u can turn disc freely
To replace pads it is either the same as front or pistons maybe be twist ones clockwise on both sides
Twist back until you can refit caliper.
Hope you understand this terminology ok
Hope it also helps
Complete job should take bout 2hours
Arthur
Fronts are easy, but the rears may be more troublesome. Here's a guide for you:
http://www.clublexus.com/forums/suspension-and-brakes/439574-is250-rear-brake-replacement-great-diy-with-lots-of-pics.html
