Clunking Sound After New Brake Pads
DieselPowerRules
Hi everyone,
Just changed my rear pads today with Mintex ones. First 30 mins they were fine. Then I noticed a clunking noise on uneven road surfaces. Its more noticeable at low speeds (under 40mph) If I go over a drain or a bump in the road there is a clunk coming from the back. High speed is fine. Everything appears to be tight. I used the original backing plate from the old pads and put grease on to reduce brake noise. When I pump the peddle stationary there is no sound. Its only when moving. Any ideas? Thanks in advance.
  • 3 months later...
