Hi folk
Stuck in tesco car park. Battery died in 2000 ls400
Got jump leads engine tyrnibg over fast but wont start, security light on dash not going out soni assume immobilisr is on
Any ideas?
Hi
On top of the fusebox there should be a yellow sticker / or in your owners handbook [ reset after flat/disconnected Battery ]
You may need to do a reset procedure, ie remove negative Battery lead then reconnect then turn key to a set position I think its acc and leave for 6 minutes then turn key and start.
Sorry Haven't my owners manual to hand , but I am sure another member will be along soon to help
Maurice
Hi folk
Any ideas?
Try this.......................
Turn key to acc position
Disconnect earth from Battery
Turn key to on position
Reconnect earth
Turn key to off
Remove key
Close Doors
Lock as usual
Unlock, start-up and drive-off
Mike
Hi folk
Any ideas?
Reconnect earth
Turn key to off
Remove key
Close Doors
Lock as usual
Mike
How did you get on??
Mike
Hi
Standard method for this is as follows (mine did it last year and RAC told me how it works).
Turn ignition key on and leave in that poistion for at least 6 minutes
Turn off ignition
LOCK and UNLOCK car
Start car
John
