Automatic Tranny Oil Volume?
Squasher
Hi, anyone know what the auto tranny oil capacity is - it says 2.0L to drain and fill in the manual, but have read several blogs stating it is 8.5L to fill from empty - bit of a difference! I'm going to flush out all of the the fluid by disconnecting the inlet cooler pipe at the base of the radiator and pump and then refill 1L at a time until it runs red. Pretty sure I need loads more than 2L, but 8.5L seems a bit high even taking into account the oil in the torque converter and pipes etc. Cheers.
I used two five litre containers when I did mine by the drain refill method, I think it resulted in an 80% new fluid replacement.
If Mercedes can fit a torque convertor drain plug what happened with Lexus?
