Relocated My Usb Port
Brettster
Got fed up of opening the flap and having wires hanging out so I've relocated my USB port to the arm rest hole. now the iPod can hide in there, ready for action with nothing on show. how it should have been in the first place to be honest.
A smart move! Yes you're right! The USB port is a very useful thing but its annoying that I have to faff about connecting/disconnecting the I pod everytime I decide to start/stop the car..
Hi Brian I have just received my 16GB Mini Scan Disc and have copied accross music from my computer as MPEG 4 files but the car does not recognise them. Do I need to pre-programme the Scan Disc so the Car can play, any help would be much appreciated. Peter
Hi Peter
Dont think mpeg4 works on this system
format the mini disc to File formats: FAT 16/32 (Windows
all mine are in mp3,below is from the audio manual
MP3/WMA FILES
MP3 (MPEG Audio Layer 3) and WMA
(Windows Media Audio) are audio
compression standards.
The MP3/WMA player can play MP3
and WMA files on CD−ROM, CD−R
and CD−RW discs.
The unit can play disc recordings compatible
with ISO 9660 level 1 and level
2 and with the Romeo and Joliet file
system.
When naming an MP3 or WMA file, add
the appropriate file extension (.mp3 or
.wma).
The MP3/WMA player plays back files
with .mp3 or .wma file extensions as
MP3 or WMA files. To prevent noise
and playback errors, use the appropriate
file extensions.
The MP3/WMA player can play only
the first session using multi−session
compatible CDs.
MP3 player MP3 files are compatible
with the ID3 Tag Ver. 1.0, Ver. 1.1,
Ver. 2.2, and Ver. 2.3 formats. The unit
cannot display disc title, track title and
artist name in other formats.
USB memory MP3 files are compatible
1.1, Ver. 2.2, Ver. 2.3 and Ver. 2.4 formats.
The unit cannot display track title
and artist name in other formats.
WMA files can contain a WMA tag that
is used in the same way as an ID3 tag.
WMA tags carry information such as
track title, artist name.
The emphasis function is available
only when playing MP3/WMA files recorded
at 32, 44.1 and 48 kHz.Sampling frequency
MP3 files for MP3 player:
MPEG 1 LAYER 3 32, 44.1, 48 kHz
MPEG 2 LSF LAYER 3 16, 22.05, 24
kHz
MP3 files for USB memory:
MPEG 1 AUDIO LAYER 2, 3 32,
44.1, 48 kHz
MPEG 2 AUDIO LAYER 2, 3 16,
22.05, 24 kHz
MPEG 2.5 8, 11.025, 12 kHz
WMA files for WMA player:
Ver. 7, 8, 9 CBR 32, 44.1, 48 kHz
WMA files for USB memory:
Ver. 9 HIGH PROFILE 32, 44.1, 48
kHz
The sound quality of MP3/WMA files
generally improves with higher bit rates.
In order to achieve a reasonable level
of sound quality, discs recorded with
a bit rate of at least 128 kbps are recommended.
Playable bit rates
MPEG1 LAYER3 64 to 320 kbps
MPEG2 LSF LAYER3 64 to 160
kbps
MPEG 1 AUDIO LAYER 2, 3 32 to
320 kbps
MPEG 2 AUDIO LAYER 2, 3 32 to
160 kbps
MPEG 2.5 32 to 160 kbps
Ver. 7, 8 CBR 48 to 192 kbps
Ver. 9 CBR 48 to 320 kbps
Ver. 9 HIGH PROFILE 32 to 320
kbps, VBR (Variable Bit Rate)
The MP3/WMA player does not play
back MP3/WMA files from discs recorder
using packet write data transfer
(UDF format). Discs should be recorded
using pre−mastering software
rather than packet−write software.
M3u playlists are not compatible with
the audio player.
MP3i (MP3 interactive) and MP3PRO
formats are not compatible with the audio
player.
The player is compatible with VBR
(Variable Bit Rate).
When playing back files recorded as
VBR (Variable Bit Rate) files, the play
time will not be correctly displayed if
fast−forward or reverse operations are
used.
It is not possible to check folders that
do not include MP3/WMA files.
MP3/WMA files in folders up to 8 levels
deep can be played. However, the
start of playback may be delayed when
using discs containing numerous levels
of folders. For this reason, we recommend
creating discs with no more
than two levels of folders.
sorry for the long waffle all mine are recorded at 320 kbps for best quality
hope this helps
brian
Brian - It was very kind of you to go to so much trouble, thank you very much, I believe I will need a clear head and a steady hand to implement.
Kind Regards
Peter
You will be OK just reformat then create a folder on your desktop
name it CTmusic so you know where it is, convert your mpeg4 to mpeg3 at 320kbps
with a program like Ashampoo Music Studio and save to folder,when your done highlight them all in the folder
then drag them to the miniusb and your done, simples
Edited by bt33
  • 3 months later...
Hi, first post after acquiring my CT last Sunday.
Yes, this has been a pain already so how did you actually do this as I can't see a way of getting under the consul to access the USB from underneath?
I basically removed the whole console and drilled a small hole for the USB cable to fit through, this does leave a hole where the USB port used to be but it's reversible if needed.
It's fairly simple to remove the console. Some bolts under the leather bits on the sides where your legs rest and some more under the felt at the bottom of the storage area.
Hopefully the pics will help
I too was scared of taking it apart.
Just sent off for a 32GB micro usb Verbatim from amazon ,I want a small one so i can shut the flap.
I converted all my music to wma with a program called DBPoweramp converter, very good and free.
seems to work better in the car if its wma.
  • 4 weeks later...
Hi waiting on delivery of my ct200h and planning out my music! Does anyone know if the flap will still shut with this USB connected:
http://www.amazon.co.uk/gp/product/B008TGKG0G/ref=gno_cart_title_1
It looks a bit higher than the Sandisk or others I have found but I prefer the 64gb capacity. Can anyone figure out if it will be ok?
