Taking The Plunge!
After looking at many cars, I have narrowed the choice to 3 2007 SEL's. I have a question! My prefered car is a 1 owner 07 reg with 48000miles and the 50000 service just done. However, the car appears to pull slightly right at 70ish on the motorway, but seems normal at lower speeds. The price will be about 16500, but could the steering be a problem? Advice appreciated! :eerrrmm:
Would check:
Are all the tyres the same make / type
Are they all of similar age / remaining tread depth / wear
Check the tyre pressures
All of those can be done free, if that still didn't fix I would look at possible wheel alignment issue? (Although I would be surprised it wasn't noticeable at lower speeds if it was alignment or even something more serious?)
