Wheels and tyres
dark_is200
Hello,
I'm new to the forum, I'm looking at getting new wheels and tyres. Currently looking at Advan Model 7 LE 19 x 8.0 with 235/35 tyres and 45mm offset.
Anyone had any problems with 19's rubbing, the HKS Hipers' have lowered the car about 50mm so just a little worried that there might be a problem with the 19's.
You will have trouble with a -50mm drop with 19's. You might have to remove the plastic arches and possibly roll the lips a bit, my advice is Try it and see!!
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
