Friday Joke
NickE
Yes, it's raining here in Northampton, and has been all day so far. Not heavy, but a constant drizzle. If you are now putting off JAE until tomorrow when the forecast is for much better weather, perhaps you need cheering up:
A major High Street bank are installing new "Drive-through" cash point machines and
customers will be able to withdraw cash without leaving their vehicles.
To enable users to use this new facility the following procedures have
been drawn up.
MALE CUSTOMERS
1 Drive up to the cash machine
2 Insert card into machine and enter PIN
3 Enter amount of cash required and withdraw
4 Retrieve card, cash and receipt
5 Drive off
FEMALE CUSTOMERS
1 Drive up to cash machine
2 Reverse back the required amount to align car window to machine
3 Re-start the stalled engine
4 Wind down the window
5 Find handbag, remove all contents on to passenger seat to locate card.
6 Turn the radio down
7 Attempt to insert card into machine
8 Open car door to allow easier access to machine due to its excessive distance from the car
9 Insert card
10 Re-insert card the right way up
11 Re-enter handbag to find diary with your PIN written on the inside back page
12 Enter PIN.
13 Press cancel and re-enter correct PIN.
14 Enter amount of cash required
15 Check make up in rear view mirror, adding lipstick if required
16 Retrieve card and receipt
17 Search through handbag contents on seat to locate purse and place card inside
18 Place receipt in back of cheque book
19 Re-check make-up
20 Drive forwards 2 meters
21 Reverse back to cash machine
22 Retrieve cash
23 Re-locate purse and place cash inside
24 Give appropriate hand signal to irate male drivers queuing behind
25 Restart stalled engine and pull off
26 Drive for 2 to 3 miles
27 Release hand brake
