The floor in both the back left passenger side and the driver side are wet (clear water). It appears to be coming from the AC vents. I suspect that the AC drain pipe is blocked. Can anyone out there help me find the drain pipe so that i can try to unblock it if that is the problem. The car is a Lexus GS300 2007.
I'd say it's more likely the sunroof drains you should be checking out first.
If you don't have a sunroof, then give your local dealer or a good independent a call, and they'd tell you where it exits.
