Self Leveling Headlight Sensor
Is this the one that is connected to the part of the front/rear suspension?
If so I had the same issue on the front one on my IS300. Stripped down and cleaned, been fine ever since. 30 mins max to do.
J
  • 5 weeks later...
  • 9 months later...
Just read Arjuna's comment that says he keeps the self levelling switched on in his 400h, I've got the same car,2009, where is the switch located ?
To my knowledge this cannot be switched on / off.
The only switch is the AFS one which allows you to switch off the swivelling function. The only time I have ever needed to switch AFS off was when travelling on the continent so as to not blind traffic coming the other way.
It is best to give the control arm linkage a bit of a lube every year or so. I see more failures reported on the LS vehicle rather than RX where they seize up and then break.
The self levelling system is on all vehicles with factory fit HID headlights. It cannot be switched off. I think Arjuna misunderstood and confused this with AFS.
  • 3 months later...
I think I have worked out how to adjust the height of the dipped beam HID lights. If I lengthen the link between the potentiometer and the suspension I think that should do it. I have done it about 2 turns and will see what difference it makes. The bolt was pretty stiff to turn so I assume the ends have friction threads.
  • 7 months later...
Hi sorry to bump an old thread but my amber warning light for the automatic headlight comes on intermittantly could tell me where the sensor is located so I can take it off and clean please its a 2004 rx300
thanks
ian
  • 8 years later...
J
I have a 07 400h, Has anyone got a video of where it is exactly, it sounds like an easy fix, but I don’t know where to start!
A very quick search of YouTube found this:
