Is220D Heaters Not Working
m4noc
Better say right from the outset, you have not really given much to respond to from your request. It could be a broken switch, a broken fuse, a turbo problem, a thermostat problem,etc,etc. It could even be due to only travelling a short distance of 5 miles or so.
Assuming it is of a more serious nature I would start by taking a look at your Coolant header tank( when not pressurised) and see if there is any presence of water droplets or the smell of exhaust fumes. Also look at the oil filler cap. Is there any mayonnaise like sludge inside it. I hope none of this is visible. If it is you probably have a blown head gasket.
I hope it's not a head gasket, but you have to start somewhere, eliminating possible reasons.
How old is the car? What mileage? FLSH? How long have you had it?
hi thanks for getting back to me i have got it fixed was told to run the car for 10 min then park it on a hill open the radiator cap and any air will find its way out then fill the radiator tank back up now i get hot air as soon as i want it
