The Woes Continue! Engine Light Check Vsc!
After having a very intermittent problem with a rough idle and a couple of stalls
On the motorway today the car went into limp mode and the dash lot up like a Christmas tree!!
Engine management light, traction control light and check vsc on the display
Now I am getting very worried and been searching all over the forums
Any ideas what the problem could be? I'm getting worried as this sounds very expensive!
Thanks in advance
I assume you have an IS220d? If so, the EGR valve is definitely the place to start.
Check YouTube for a video on how to remove and clean it. If you have a basic socket spanner set you can remove the EGR valve and check it with pretty much zero mechanics knowledge. Believe me, it is a really simple job!
Good luck an hope you get it sorted!
Also if you're interested, it's probably worth buying an OBD II connector from eBay if you have a smartphone. These things cost less than £20 and you just plug them into the port just above the pedals. Then free apps for your phone will give you all the ECU error code info you need. Much cheaper than £90 to have Lexus read the codes for you!!
I think I may purchase one
It's very strange as I had a service done 2 weeks ago and specifically specified that they cleaned the egr valve!! Which they confirmed after they did it
The car is booked in the garage tommarrow to be diagnosed so I don't know if I should look myself today also what's even stranger is that this happened when I was on the way to Cambridge which is 100 mile trip so had to get home and I drove home today with the lights still on at about 80mph with no problem and just got in the car and the lights have now gone off??
If the fault doesnt register again with the ECU after 3 engine on/off cycles then the fault is no longer there and will be stored as history in the ECU and the lights will go out. Get the codes read and you can find out what caused the lights to come on in the first place :)
It's not that strange. For example I had a leaky fuel injector. Every month or so it would drop petrol into the cylinder after I turned the ignition off and cause the car to run on. That would then trigger the ECU to detect a misfire so sending the engine light on. It wasn't a permanent fault and the computer realised that and after 3 cycles turns the light out. I think it's a clever system as the codes are stored so you can work out what's going on without worrying that there is something major at fault.
Make sure you have good long test drive. In fact do 3 on separate days. If it still suits then go for it. Zero road tax ain't to be sniffed at!
I found it a little disconcerting when's drove my mates. It felt and sounded like the engine was revving way too high, guess its summit you have to get used to. It's darned quiet on Battery power though!!!!
Yeah I keep reading the pros and cons and I'm not sure it will suit me as I have read that you generally get more mpg on A roads and city driving than longer drives
And as I do 3 or 4 100+ miles trips I may be better of with a diesel whic may ultimately sway me over to a c class blue efficiency sport
I had the CT200h on 48 hour test drive about 6 months ago. My wife and I were going to both sell our IS200's and share the CT and buy brand new (something neither of us have ever done)
We still both drive our old IS200's..... We hated it except for the fuel consumption obviously! Lol :)
I had A Check VSC warning on my 220d. Took it back and it was cleared from the 'puter.It was thought to be dirty brake sensor. That was nearly a year ago.
Have you ever put a tin of BG244 through the tank?
Ok, if they have an OBD2 code reader then they have one that doesn't :-
A. Read manufacturer specific codes
B. Doesn't read stored history codes
Lexus or Toyota will be able to read the codes for you and give you a diagnostic as will most garages to be fair. My garage reads Lexus/Toyota codes just fine.
Once you get the fault codes, which believe me are stored on your cars ECU then you will know what triggered the lights to come on. :)
Yes I put it in before the engine light and check vsc came on
I'm just wondering if that had anything to so with it?
May just be. I also had one after brakes work at the dealers, went off following day. Never saw it again.
Yeah the garage it is in is a Honda dealer where I bought the car and they said they will speak to lexus in the morning
I have a feeling it will be going to the dealers as last time I had warranty work done it did
On the plus side if it does go dealers I am going to see if I can arrange for a courtesy car and see if I can get a ct200 to see if it suits my needs
Another quick update
The garage have been in contact with lexus and have managed to get the stored codes from the ecu
The code returened was P0400
Which is the egr valve
It has been authorised by the warranty company and is being replaced
Hopefully this will solve the issues
Strange that the egr valve was actually replaced by lexus 40,000 miles ago
Wish you were closer. I'd be tempted to come and take it off myself, just ti get a good look at the inside and seating of the valve itself. Generally, they don't need replacing they just need a bloody good cleaning when removed from the car.
It is such an easy job to do.
