Front Fogs Is200
keeny
The housing are all the same so they will definitely fit in the bumper. But you need to check the wiring though, as the earlier ones used an HB4 or HB3 I think like the ones used in the headlights. Whereas the later spec foglights 2003+ used an H3 bulb with a different plug.
cheers sprinter only seen a set of smoked on eBay stating for is300 2000 to 2005 didn't know if they would fit or not been waiting ages for other set that i ordered but his supplier messing him about,might go for the smoke ones then
cheers sprinter only seen a set of smoked on ebay stating for is300 2000 to 2005 didn't know if they would fit or not been waiting ages for other set that i ordered but his supplier messing him about,might go for the smoke ones then
remove the fog light the one you got and see (take picture) which harness connector you got. that way you won't bought the wrong item.
hope this help :zee:
