Heater Control And Fag Lighter Bulbs
keeny
please please please can someone give me a complete list of what smds i need for heater controls,fag lighter and ashtray dash nearly in darkness would be most grateful
thanks guys
thanks guys
The ciggy lighter and ash tray are a T5 LED, one of these.
As for the heater controls you'll need this type,
But if you replace the stock bulbs with these most people find them not bright enough!
Theres a tut on another forum that works so much better, but its a PITA of a job to do but well worth it.
This is what you'll end up with with that better mod.
The bulbs in the pic for the heater are called neo wedge bulbs.
Their a straight swop just make sure you have the polarity correct for them to work!!
If you just replace your orig orange ones with these it will NOT give the same effect as the pic below.....
This is a much much more complex producer that will make you loose your hair and make you swear like a trooper trying to achieve the look.
Its on another forum mate, and if i put it up it will be removed, and i cant pm it to you as that would be breaking the rules...
Email me and ill forward the tutorial.
