Sat Nav Time(Problem)
Guest bigbullhead
Guest bigbullhead
I was coming home on Sunday morning and set my destination but the arrival time was showing my arrival to be an hour later as the clocks had changed but the sat nav had not so does anyone know where to change this( before I read the manual) as I have looked in the menus but can find nothing do you have to re install the disc????
Hope someone can help as its sending me nuts!!!!
Sat navs get their time from satellites which are one of the most reliable sources for time. It has to be the settings.
In the setup screen there is an option called Time-zone on the first page. Go into it and check you daylight saving settings.
