Check Engine Light 2003 Gs430
hellom8
This morning the CEL came on. The car has no symptoms.
Is there a way to read the CEL codes with out a code reader?
My old Scooby had a couple of wires under the dash that you would connect and the CEL would flash the error code for you, just wondering if Lexus has something simular?
Cheers.
Ian.
The cheaper ones should work no problem on yours. It was 1999-2000 GS300's that wouldn't work. My 2001 GS430 works no bother on the cheaper ones, although they can trigger a vsc light to come on. The reset procedure I posted up a few days ago for that, if it does happen.
Got my code reader today.
Gave me one code.
P0135 $10 1/1 Generic
O2 Sensor Heater
Circuit Bank 1 Sensor
1
Freeze Frame
DTCFRZF - P0135
FUELSYS1 - CL
FUELSYS2 - CL
LOAD_PCT (%) - 22.00
ETC(oF) - 178
SHRTFT1(%) - -0.8
LONGFT1(%) - -9.4
SHRTFT(%) - 0.0
LONGFT2(%) - 7.0
RPM(/min) - 600
VSS(mph) - 0
LAT(of) - 46
The car is under warranty and senors are included so the garage will be taking a look at it.
Guessing they will put a new sensor on the car, this might also explain my below average mpgs.
Cheers.
Ian.
Gave me one code.
O2 Sensor Heater
1
Freeze Frame
DTCFRZF - P0135
FUELSYS1 - CL
FUELSYS2 - CL
ETC(oF) - 178
SHRTFT1(%) - -0.8
LONGFT1(%) - -9.4
SHRTFT(%) - 0.0
LONGFT2(%) - 7.0
RPM(/min) - 600
VSS(mph) - 0
LAT(of) - 46
Cheers.
Ian.
bit of a result if it is covered under warranty :hohoho:
As you predicted, the VSC lights have triggered. I found your pin diagram and instructions on another post so will give that a go.
Cheers.
Ian.
Worked a treat, no more VSC lights.
Cheers.
Ian.
Good stuff :)
Had the sensor replaced under warranty, garage said they billed the warranty company £140 for the job.
Anoying thing is after five miles the CEL came on again. Took the car back and the second senor has now gone, so this has to be replaced now.
Cheers.
Ian.
  • 4 weeks later...
