Bluetooth Profiles (Lexus Connected Services)
From reading through the manual of my MY13 RX 450h, I’ve gone and registered for a portal account with My Lexus Connected Services. As per the FAQ on the website, “In order to use this service, a Bluetooth DUN/PAN capable cellular phone with a valid data plan subscription is required.” (Here's a screenshot incase it wants you to login to see the FAQ)
I’m a bit of a geek, but for those that don’t know the difference between the two bluetooth profiles:
  • DUN is using the phone as a Dial Up Networking modem. It creates a virtual modem through the Bluetooth connection to your paired device (laptop, car etc) then dials your provider directly for an internet connection. You need provider specific information, such as the Access Point Name, correct number to dial, the correct initialization string, and possibly a username and/or password.
  • PAN is creating a personal area network, to provide a hotspot. Your paired device (laptop, car etc) doesn’t have to do any dialing or anything.
Anyways, in the car I go into the detailed Bluetooth settings and this is what profiles it shows me as supporting:
HFP, DUN, OPP, PBAP, A2DP, AVRCP, and MAP.
So that’s contradicting what the Lexus website said as there's no PAN. How do I enable PAN on my car? Does it need a software update from Lexus or something?
Why does it matter so much that the car only does DUN whereas the Lexus website says it should do PAN too? Because the Apple iPhone only does PAN not DUN.
Anyone got any ideas on how to get PAN working?
Cheers!
  • 3 months later...
hey - just found this - I'm in a similar position - my Iphone only gives me the option to set up a hotspot. To make things worse I am with EE (formerly Orange), and I think I might have to pay them a daily fee!
Did you manage to get anywhere with this?
EDIT - I can create a hotspot with my Iphone (4s) and get my iPad/PC to connect to the internet with no problems, but don't know if that will work in the car!
  • 3 months later...
I will check this out and try to help sort it when I pick up my GS450h on Saturday as I want to get this working too.
What are the costs for the service, or is it free? What does it enable you to do? (I can't see as I don't have my VIN or device ID yet)
There were similar issues with Parot Bluetooth devices which were fixed in IOS updates - maybe worth checking your version.
Pete
  • 2 months later...
Has anyone solved this yet?
I have a Blackberry Torch 9810 and have set up a My Lexus account, but when I try to search online I just get a Data Connection Not Possible message . I guess this could be the phone (I'm not technically minded at all so will struggle knowing about PAn etc etc).
  • 6 months later...
