Squeaky Sound (Again)
Hi everyone
Bet this annoy squeaky sound is :tsktsk: NEVER :tsktsk: let us alone or it's just me that i love my car and want everything to be perfect smooth ride. :driving:
the sound come and goes depends what the weather actually is :hocus-pokus: .
can't figure the exactly sound from and defo not the wheel bearing as the stand still engine running the sound is there. i'm no mechanic but suspect the steering wheel pump or the belt need (recent changed a year ago)
hope anyone can share their experience or any annoy sound that need to be aware off.
thanks :zee:
Dude! my car has also just started doing it again! it has to be the weather. Just as i thought it was gone for good :msn-cry:
Mines getting its cambelt and belts, WP etc done in a couple of weeks so will get my mechanic to take a look then, cant be arsed to be messing around with it when its this cold out!
I noticed my belts squeeked when cold (not the cambelt) the 3 aux belts at the front if the engine. I just tightened them and the noise went away.
all 3 belt u mean?
was thinking the steering pump faulty :geek:
For me it was my power steering belt. I tightened all 3 just to be sure. I also had the squeel from the back brakes. Lexus sorted that for me when it was in for a service
will give it a go this weekends (hope it's sunny day :hohoho: )
i did replace the rear disc plate... as i had a big pot hole bang recently and the base guard plate (small bracket) that saperate the hand brake line some how broke (rusty n corroded) and was sitting inside the rear disc plate making sound... all sorted now..good time :innocent:
  • 7 months later...
Are these difficult to tighten mate ? Mines started doing the same damp or cold
  • 4 weeks later...
If your belts are squeaking try getting a bar of soap and rub it along the underside (not while the engine is running!) Crank the engine half a turn and repeat. Its worth a go if not its new belts.
