Is200 Front Brakes - Brembo Discs & Pads
Sherbertmelon
Hey!
Long story short I recently went to the local garage to have my brakes checked due to excessive brake squeak, I was told the discs are below 30mm (27.9mm they were at) which apparently is bad and was also the cause to the unbearable squeak that keeps occurring.
So I need some new discs and pads, got a quote and it looked a little high (I'd been doing some research for my IS before hand). I was quoted £70 per front disc, bare in mind they're Flat brembo Ventilated 296mm discs, but on eBay for both front left & right they're only £100 for the two:
http://www.ebay.co.uk/itm/FRONT-Brembo-Brake-Discs-Lexus-IS-200-Saloon-GXE10-1999-2011-/270930900015?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ALexus&hash=item3f14bd742f
So is worth my time getting some of these, for an additional £20 or so!
http://www.ebay.co.uk/itm/LEXUS-IS200-IS300-1999-2005-BREMBO-DRILLED-GROOVED-FRONT-BRAKE-DISC-/330352480209?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cea8acfd1
or
http://www.ebay.co.uk/itm/LEXUS-IS200-BREMBO-FRONT-DRILLED-GROOVED-BRAKE-DISC-/270431412935?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ef6f7e2c7
Would just like to know peoples thoughts! and advice..
P.S. I have brembo pads & calipers, so would I be needing a new set of these (I was advised to)
http://www.ebay.co.uk/itm/FRONT-Brembo-Brake-Pads-Lexus-IS-200-Saloon-GXE10-1999-2011-/270922147136?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ALexus&hash=item3f1437e540
one word.. its brembo. so will be good for sure. I looked at them a while back aswell and will def opt of them when am due new pads and discs. but saying that, the Pagid brake discs and pads I got from Eurocar parts are doing a good job in stopping the car effectively. I don't use it for tracks but how long they will last I don't know but if you have funds for Brembos then by all means but worth double checking to make sure they are genuine brembos tho.
I fitted a pair of http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180464646215&ssPageName=ADME:L:OC:GB:1123'>THESE two years ago and they've been spot-on. No cracks, warping, squealing or anything else that is often associated with having grooved & drilled discs. A bargain at nearly half the price of those brembo ones.
I have blank Brembos on the rear and they've been fine. The bell on both discs were orange with rust within weeks though so I doubt that Brembo's OEM-spec stuff is of any higher quality than any other reputable brand out there.
Hey!
So I need some new discs and pads, got a quote and it looked a little high (I'd been doing some research for my IS before hand). I was quoted £70 per front disc, bare in mind they're Flat Brembo Ventilated 296mm discs, but on ebay for both front left & right they're only £100 for the two:
One small thing i notice when changing disc on the IS the Toyota/Lexus originals are painted black in the centre where they sit hub assembly. it obviously doesn't effect performance just looks better. and provides a better finish for longer as it will not show up the inevitable corrosion and brake dust build up.
