The cutoff looks decent for a halogen projector. I've seen a lot worse.
What change in beam pattern are you referring to? Do you think there's something wrong with the foreground lighting or are you referring to the cutoff on the wall?
I am not sure what you are referring to in the pattern but if you mean the 'step' on the cut-off as shown below than yh that is normal. The right side of your beam should be lower than the left so that you don't flash oncoming traffic.
__________
\__________
You might need adjusted for mot.i had hid on my mazda failed mot coz of it pain in the *****.if it fails mot take them out for it then put back in after
all sorted now, got the same as you!, turn out my headlights needed some serious realigning especially as the car has now been lowered, i really couldn't see anything when driving on motorways because of how low the cutoff line was but now its changes and forms a perfect z shape!
