Does anyone know at what stage the of starting the car the immobiliser steps in.
if the ls400 is immobilised will a key turn get no response? or will the starter motor turn it over but it just wont start.
Anyones experience appreciated
Oliver
The imobiliser is an electronic chip and transponder on the 99 lexus ls400 and comes into play on exit of ignition key from steering lock.This sends a signal to the engine ECU which cuts the signal to the engine after two seconds after it as been started if not by normal starting procedure,(using the original factory supplied ignition key)
The only way it can be fixed is by the factory as they hold the original electronic settings.There is an excellent article regarding this subject on this site. www.oldschool.co.nz how to wire up a 1UZ (VVT-I AND NON VVT-I)
