Some New Pics ;-)
Just thought id put a couple fresh pictures up after she was cleaned yesterday....
Im thinking of trying to install a Nexus 7 tablet to use as Sat-Nav and music etc...
Any thoughts?
post-44971-0-05049800-1367914222_thumb.j
post-44971-0-62738400-1367914233_thumb.j
post-44971-0-81267400-1367914252_thumb.j
I'm not sure if I should try and install it permanently in the dash which would require wiring etc or to set it below the current single din Sony head unit...
This may be what I do as the head unit is Bluetooth so I can use A2DP for the music and also Sat Nav as well...
some might agree that it would ideal to install a double din with all "extra" as you weren't sure what "to be or not to be" issue :geek:
if the wiring mod done properly you can sell it off as a unit "plug and play" thingy depend on what gadget mod on.
too much hassle? could try this out Item number:370770222009 on £bay
would spent on service then gadget as you done pretty good job keeping your car clean up and running smooth :driving:
good luck :zee:
