Front Fog Stand Alone Mod
Hi guys just a quick one there is a guide on setting front fogs so they can be on without lights on. Says u bent pin on relay and connect female spade and put other end of wire into ignition fuse however when I did this they still don't turn on unless lights are on so it doesn't make any difference. Has anybody else on here done this and is it different for UK spec to us spec as only seam to find guides that are in US.
Thanks, Jason
Hi Jason, i'v not seen a guide for this mod on the net at all, but i think by doing it and turning them into DLR (if thats your intent) you might find the police pull you for them!
