Radio Cd Player
Stumoz
I'm sure you are correct to look for this.....but do be aware.
There are several different models in this range. Some are top loading CD, some are bottom loadingCD and some require an external amp. You don't want to make a costly mistake.
The bottom loaded CD were the ones that seemed to go wrong more often. Hence the redesign on later models with top loading.
Good luck in finding the right one.
