Need Tyres And Fitting Centre
ilovemylexusi200
I just brought a new lexusi200 does anyone know where I can get
tyres and get them fitted?????
Any tyre place will hold tyres for your Is200, they are a common size.
But it may be worth spending a an hour or two trying to work out which ones are going to the best for
http://www.blackcircles.com/
http://www.valuetyres.co.uk/
The IS200 has a tendency to wear out it's tyres quite quickly. It will be worthwhile getting the alignment done by WiM http://www.wheels-inmotion.co.uk/ as this will cure the cars thirst for the inner edge of the front tyres and the camber of the rear. This will cost £115 on its own though.
I went for tyres that were classed as ECO. Low rolling resistance and good for wet weather grip, Lexus UK recommend Bridgestone as they are much more durable. Then you have to factor in what price you are looking at paying.
This bit is IMPORTANT!!!
Lexus UK will promise to beat any Price including fitting on the street. NOT INTERNET DEALS as they often simply send you the tyres to then find a fitter.
Find the tyres, find the price, then ring Lexus.
^^ what Stuart said, plus if you're running on the factory 17" wheels, the tyre size you need is 215/45/R17.
And make sure the weight rating for the tyres is 91. This is the correct weight rating for the IS200/300. Most of the ones on retail are rated at 87 for this tyre size, which is lower than spec and could accelerate tyre wear.
  • 2 months later...
  • 1 month later...
