Hello
My passenger side HID is not working properly. When I switch it on, it will be on for about 5 seconds before it is off. I just replaced the bulb (cheap eBay bulb) and it had the same behaviour,
Do you guys know what could be the issue? Would it worth getting a proper Philips bulb?
If it is the ballast, how much would that cost to fix? :-(
Simon
Just had exactly the same.
The flicking on for a while suggests lamp is going and the ballast is trying to fire it up i was told.
Lexus Milton Keynes ordered and fitted straight away.
Was £105 . sounds a lot for a bulb, but it runs at 20,000 volts apparently.
Been a good a gold since.
PG
