Hubcentric Spacers Fitted
Stuart Aspey
hey stuart, how you doing '
have you tested it in terms of handling like around corners ?
what mm spacers you went for ?
not sure about the grip in corners but your going to get a lot more tyre life i can tell ya '
I purchased them off a fellow IS driver, but I think they are on eBay for around £65 a pair. I've gone 15mm at the front and 20mm at the rear on each hub, so a 30mm total width increase at the front and 40mm at the rear.
As for improved handling . . . I think it feels better? But until I change the centre of gravity . . . Lower him, the improvement is probably negligible. It'll look so much better with my 17"s on.
  • 1 year later...
in all honesty mate thats barely going to make little no difference in handling, you have increase the track by 4cm, you would notice more of a difference upgrading the tyres.
looks good tho, cant fault that
As you have increased the front track you will find the steering jeometry will not be 100 % as everything would have been set up for standard track.
To get the best handling the steering geometry should be adjusted accordingly to keep everything correct.
Your insurance could reject a claim if it has not been done correctly & notified to them of the change.
Sent from my SM-G920F using Tapatalk
I had 15mm and 20 mm on mine and did have the geometry reset and it did make a difference in handling. Bends and roundabouts I took regularly felt much more stable and it also makes it look so much nicer filling the arches the way they should have been. I have 8 1/2 by 18 inch wheels now so don't use the spacers, so if anyone wants them message me.
