Sign in to follow this
John Lee
Idling Rpm
Hi all,
may I know what's the normal idling RPM for IS200 NA ? My idling fluctuate between 700 to 750 rpm, is that too high??
Is the air-con switched on?
Yes...
But with or without air-con, the idling RPM is about the same for my case.
are you using some kind of rpm digital meter?
i am getting 640rpm at idle
i find the factory tahcometer is not as accurate as the digital rpm meter
over 700 without air-con, over 800 when on for mine
I estimated the rpm based on the needle position on the tahcometer.
what's the difference of reading between the analogue tahco and your digital rpm meter ?
Normal with the air-con on. But should be around 600 with it off.
i find the tacho and my rspec digital rev meter give different reading
when the digital rev meter say 1000rpm, the lexus tacho give say around 1100 to 1200 rpm
i don't know which one is correct but i know they are different
and also, sometime my rev get down really low..... (digital rev reading) it is usually at around 680-640....... sometime the engine idle at 590-560
u can acutally adjust the idle urself if u know how....... there are two screw on top of the throttle body..... they should be cover with a little white paint, i think lexus use it prevent ppl playing around with it
but if u r not sure... just goto lexus they will adjust for u
