Clutch Kit
jeffrosie
From what I've read all the 3s engines and jz engines share flywheel and clutch spline patterns. Oh and the rx8 for some reason.
Will check on a parts database tomorrow and get back to you
Does the IS300 use the same clutch and gearbox is US?
Nope....manual on the 300 in US is 5 gears not 6 and it's a hell of a lot better than the 200's gearbox apparently.
In my opinion the manual transmission lets the 200 down. It's clunky and notchy and since changing to an auto 300 I've noticed such a difference :)
That's interesting actually. Was it just the spacing of the ratios that made the 300's gearbox better, or was it the shift feel, durability, etc?
I've been curious about this too, but couldn't find anyone who could compare these two gearboxes side-by-side, because the IS200 wasn't available in markets where the IS300 manual was sold.
same ones used in GS430/LS430 V8's Ganesh...smooth as you like.. and can apparently handle a lot of torque through it 350-400 bhp with just a valve body upgrade for the auto and manual is the W55 gearbox
