Altezza Gita
I plonked some news on the front news page in regards to the Altezza Gita... now this was the lastest news from Auto Asia but i cannot define the difference between the Sportcross and the Gita?
anyone know?
Length 4,505mm
Width 1,725mm
Height 1,420-1,435mm
Wheelbase 2,670mm
Ground clearance 135mm
Turning circle 5.6m
Dry weight 1,520-1,540kg (3.0)
1,360-1,410kg (2.0)
Kerb weight 1,795-1,816kg (3.0)
1,635-1,685kg (2.0)
Fuel tank 60 liters
Engine 3.0-liter BEAMS 2JZ-GE VVT-i straight-6
Capacity 2,997cc
Power 220ps (162kW) @ 5,800rpm
Torque 30kg-m (294Nm) @ 3,800rpm
Compression ratio 10.5:1
Fuel economy 8.0-9.8km/l (Japanese 10-15 mode tests)
Engine 2.0-liter BEAMS 1G-FE VVT-i 4-cyl
Capacity 1,998cc
Power 160ps (118kW) @ 6,200rpm
Torque 20.4kg-m (200Nm) @ 4,400rpm
Compression ratio 10.0:1
Fuel economy 11.4km/l
Prices in Japan
AS300 4x4 4AT Y2.89-3.28 million (US$23,210-26,345)
AS300 5AT Y2.76-3.00 million (US$22,170-24,095)
AS200 4AT Y2.19-2.74 million (US$17,590-22,010)
AS200 6MT Y2.18-2.72 million (US$17,510-21,850)
