WHAT IS SUPERCHARGER
there are different types of supercharger or compressor as it is also known.
basically i will deal with the type that can be fitted to the IS200.
it is a unit that has rotating shafts with lobes inside,as the shafts rotate the lobes on each shaft compress the air between them this air is forced into the engine increasing the air/fuel mixture in the cylinder for a better/stronger combustion.......
the supercharger is driven by the engine, normally from the crankshaft by means of a belt,so all the time the engine in running so is the supercharger.
