Spacers For Standard 17" Wheels?
This was mine at 15mm Front and 20mm Rear.
I think 10mm Front and 15mm Rear would have done the trick too. H&R and Eibach have a good reputation but you don't really need to get them if it's just for a short period of time.
Cheers Jami. Love that side-on view.
To be honest I will still want them spaced when I replace with 18s, however need to confirm if that will change the spacing.
I will search fleabay for some 15/20 or 10/20 and see how I go.
Just to double check....did you need to change your OEM wheel nuts? Just reading the H&R site and they say some might not be long enough? Don't understand why not as it would be the threaded bolts which would need to be longer...buy hey!
Agree with the post above. You need hubcentric spacers with a PCD of 114.3 and a center bore of 60.1mm.
If you google around, the use of spacers has a lot of hate on most forums. If upgrading to 18" just go for a more aggressive offset and get rid of the spacer.
