Sd Card Reader
Hi
Just noticed the micro-SD card reader on the dash, I have been told the SD card has the maps and shouldn't be removed...
So it seems for playing music via SD card is not an option on IS?
I think that's the case for the Nav SD slot, but just get a micro-SD to USB adapter and use one of the 2 USB ports - that's what I use.
It's ok to remove it, I have to check what version I'm running. What happens if you put a different card in I've no idea. I'm not going to try either!
