Squeaky Brakes
paulinroyton
Hi.
I have a Lexus IS200. My car has started making a strange sound when I drive. Its like a squeaking noise as I drive. I have had my car into a garage and the mechanic can not find anything wrong with the car.
The noise is similar to a train coming into a station. The mechanic did check my break and said there was nothing wrong with my car.
Has anyone any ideas what could be wrong with the car.
Paul.
  • 5 weeks later...
Mine did this. Never did find out what it was. but everything was in good working order. I checked back plate, calipers, pads and looked for debrie and it still did it
Squeaky brakes can be down to the following reasons
1/ rust on the edges of disc
2/ cheap or worn pads
3/ cheap discs
4/ metal dust trapped inbetween the disc and caliper
Personally, I would clean my discs and remove all metal dust and copper grease up and refit. Should do the trick.
Hi Guys and thanks for reply.
The noise is intermittent. I did let a mechanic have a look at my car and he could not find anything wrong with brakes. I recently have had the car serviced and replaced cam belt and fan belt.
Paul
