Brakes
Kikokami
Hi to all first time in here just would like to ask you guys if you could help me with my Lexus gs300 it has a strange noise inside when you drive it's like you hear beeee and water running through pipe and it stops when you press the brakes also got lights on dash attention mark,stability control,beake light
Would appreciate any of your help
Many thanks
I have same noise on my GS430. Having stripped nsf wheel and caliper I noticed the seals have split so I suspect a partially seized caliper. Hopefully going to repair this weekend, will get back to you.
Hi Kiko,
If you have warning lights on the dash I would have a fault code read done in the 1st instance, this should assist in diagnosing the problem.
There is a known problem with the brake accuator system on the series II GS models but don't jump to conclusions just yet.
