Dmf And Clutch
notbad
  • 4 weeks later...
Hi has anyone fitted clutch kit and flywheel from a avensis 180 to Lexus IS 220d yet keep looking through this and still can find a 100% answer I have just bought the full kit from a seller on eBay as its same engine codes but don't know if I have done the correct thing or not thanks
Sent from my Iphone using Lexus OC
  • 7 months later...
Hi Adam, it is possible to create clutch judder on newly fitted clutch if the cover wasn't installed correctly and the cover fingers are now distorted causing the release bearing to rise and fall under rotation which you would feel through the pedal and the drive take up would not be progressive causing judder.did you fit the clutch yourself?
