Front Disc Splash Guard/shield
eigenvalue
Thanks for your comment. Yes, it is the front splash/dust disc brake shield and I have now got one via the dealer. I felt that one from a breakers would probably be pretty rusty, and they are such a pain to change since the hub has to be removed unless the method recommended by Tigerfish can be used, i.e. cutting and bending over the hub. I changed the offside shield 2 years ago and removed the hub at that time. I don't know whether or not it might be an MOT fail with a missing/broken shield?
The original was so rusted that it simply fell off as soon as the wheel was removed. Because these shields rust so badly, I give them a couple of coats of black Hammerite before installing hopefully for some extra protection.
Well its definitely not an mot failure... And i can't imagine that one from a breakers would be to bad as mine an 04 plate and they seem fine and i know theres an old 'v' reg sat at a breakers with a seized engine and they seem fine aswell(as i checked today)... But i am glad you got it sorted!!!
Thanks for the information. The job's now done and for anyone else needing to do this, it's very easy to cut through the thinest part (1/4") of the new shield and bend over the hub and then straighten out again. This is definitely the way to go and avoids dismantling the hub.
I reckon it must be the seaside air and winter road salt up here in Scotland that makes things rust so badly!
