18Mm Bolt
Wonder if anyone can help. This morning I found an 18mm bolt on the pavement at the entrance to my drive. Not sure if this has dropped of my 2007 is250. It looks like it's got black paint/under seal on it. Anyone have any ideas? Could it be off a brake calliper or suspension strut. Any help would be appreciated.post-17535-0-75786000-1409502517_thumb.j
Looking at the threads towards the end they look a bit chewed up, if that is the case I doubt it would have been easy to get out nevermind fall out, reckon someones planted it on your drive to panic you :)
Can't say for sure...but have a check around each wheel arch and also the underneath area of the front bumper (i'm thinking here about the bolts on the spats and the very bottom underside of the wheel arch).
Judging by the shadow I'd say the threads are OK but the threaded body may look a bit chewed as it its not quite in focus.
Keep hold of the bolt as you may a position for it at a later date.
