Is any one having problems with the remotes for the door locks on their GS300's? I have to get right up to the car before it will activate the locks. I have had the battery checked, and this appeares to be ok.....:(
Shrek
I agree with Rodders, I think you need to change the battery.
PS, from memory the pickup for the alarm is on top of the dashboard (looks like small dome) if you point the remote at that you might get a better responnse?
  • 1 month later...
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
