No Amplifier. Need To Change The Rear Speakers?
wmerlin
Hi everyone.
I was struggling to ask this for a while. I did read through a lot of topics regarding the stereo topic.
The story is: My head unit that came stock does not have a working CD player (ERR1. I did clean the lens, etc, it does not work at all. (I can eject CD-s, but cannot play CD-s))
So I want to add an aftermarket HU with Bluetooth built in. So I ordered a facia, and a cable that is an adaptor from the original connections to the factory HU to ISO connections.
I did not buy the HU yet, but I did read through the audio system related topics, where I see that I need to bypass the factory Amp. I did check, there is no AMP in the car. (I did check behind the glovebox, on the right (I have left hand drive car). (as a sanity check, I checked the left side as well, no amp :) )
So now I see that some guys claim that the factory rear speakers will not work with the new HU, as they include 2 speakers? Arent they a 2 way speaker? They only have 2 wires going to them. I did re-build some car audio systems at home for my earlier cars, but I did not meet a similar thing so far.
If I have 2 cables going to the rear speakers, so I think this means I have a 6 speaker system without amp. In case of a 8 speaker setup, I should see 4 wires going to my rear speakers right?
Prove me if I am wrong, but if I have no amp in the factory system, i should be able to directly connect the new head unit through an adapter cable.
Does anyone have an idea or opinion about a NO amp version headunit installation?
  • 5 weeks later...
Not too sure if I am replying too late now as to whether you may have sorted the question you have. But never the less.
If you have looked behind the glove box and you do not have the amplifier then your life will be so much easier. I had an amplified system that I had to bypass with the bypass lead. I am assuming that the stereo wiring on a non-amplified system will just need the ISO lead to convert the Lexus wiring to a ISO connector.
The factory rear speakers IF you have an amplified stereo will have 4 wires as the rear speakers have a mid range and subwoofer built into them. As yours is not a amplified system and only has two wires, then im assuming you only have the mid range rather than both. You should be ok not to replace the rear speakers. Unless you wish to replace your rear speakers with another set of 6x9's. If you do plan to replace your speakers, front or rear speakers, then you will need to make MDF baffles to mount your new rear speakers onto.
Basically use the standard speaker as a template and cut to fit your new speakers and bolt in place. For the front speakers they are riveted onto the door, so you will have to drill out the rivets. I used 15mm MDF for the rear speakers and 3/4" MDF for the front speakers with sound deadening to bring the speakers out a little more as they were catching on the door glass.
Hope this gives you the information you was looking for.
Dean
Dean
Thanks Dean. I did not make the conversion yet, as I do not have the final headunit. I however did get a headunit for testing. I will check it either this weekend or the next, and will get back to you. The MDF size info is very useful, thanks!
Ferenc
  • 1 month later...
Dean
Hi Dean, finally I had time to do the check. The rear speakers work fine, with no modded wiring, all lines that run to any speaker are factory wires. Now I only need my final HU to be purchased.
Just a general info if anyone needs it, this fascia adapter is the one that has a VERY strong build quality. It does not match 100% the dash color, but the quality is exceptional.
http://www.amazon.co.uk/Celsus-AFC5224-Stereo-Fascia-Lexus/dp/B006VV32QQ/ref=sr_1_1?ie=UTF8&qid=1418538933&sr=8-1&keywords=is+200+fascia
  • 4 months later...
Hiya,
Glad you got it all working. I ended up running complete new cable through the car as I wanted an amplifier to power all speakers that I have replaced.
Hope you enjoy your new speakers.
Dean
At last I have fitted a Kenwood dpx 306 double din unit in the dash. I only needed a harness and an antenna cable extender to connect it to the original connectors, and thats it.
All works fine now.
Did you use the metro tyto-01 harness or? I ordered one but it's missing the plugs so have to get a few days off when weather is nice so I can tinker ( garage is full of stuff ).
I saw someone post a facia earlier and I got the same one, was very poor quality and it eventually got binned. I'll check my emails for the order I placed for second facia, which is very easy to build and fit and surprisingly robust concidering the parts just clip together.
I live in Hungary, so I ahve ordered an adapter from a local store. It looks like this:
http://www.autoradiokeret.hu/components/com_virtuemart/shop_image/product/Toyota___ISO_r___4a12953bb545e.jpg
I see this one to be similar:
http://www.ebay.co.uk/itm/Lexus-IS200-Car-Radio-Wiring-Loom-Harness-ISO-Adaptor-/350395370141?pt=LH_DefaultDomain_3&hash=item5195310a9d
I have ordered a fascia first, which was terrible, then I asked for a CELSUS made fascia, that was VERY robust, just as you say. I went for a 2DIN unit, so I had to use the original "loosy" one, as it fitted the 2din unit better. It turned out that the "lousy" one matches the dash color better.
Also you need something like this, if the antenna connector is not on the same side as the original radio:
http://www.ebay.co.uk/itm/Car-Stereo-Radio-Antenna-AM-FM-Extender-Lead-Adapter-Cord-DIN-Male-to-Female-/281007126522?pt=LH_DefaultDomain_3&hash=item416d5477fa
Have a great day in installing the new radio. I always liked a day like this.
Mine looks like this after finished:
http://kepfeltoltes.hu/150502/IMG_20150324_071915_hdr_www.kepfeltoltes.hu_.jpg
  • 2 years later...
