[Is200] Problem With Mirrors Control
sha4ky
Hi Forumers,
I'm lucky new owner of my Lexus IS200. Unfortunetly when I'm buying my Lexus I won't check mirrors control (setting and folding) and it doesn't work... Meanwhile after buy I also replace car Battery, and first thought was fuses.
I found something some manual:
AcdMdvR.jpgAcdMdvR.jpgAcdMdvR.jpgAcdMdvR.jpghttp://i.imgur.com/AcdMdvR.jpg (I can't set it as image)
And I check these two fuses : MIR HTR and RADIO NO.2 and both are OK.
What else I should check? Anyone have similar problem?
Big thanks for any clues.
the wiring is straightforward for the mirrors on the IS200, there is no ECU involved. Radio No.2 fuse provides power to the master switch assembly and the power is directly switched to the mirror motors.
I would check the wiring connectors at the mirrors and the operation of the main switch assembly.
post-3469-0-52462900-1412881438_thumb.pn
